HELP, crazy intermittent problem with engine, VCT????
TonyN
Ford Junkie
Virginia Beach, VA
With mild cams like NSR cams, I recommend retaining the VCT for the fattest power band possible. It wouldn't 'hurt' anything by installing lockouts but it would need to be tuned for it and you would probably lose a few ponies at either end of the power band depnding on where they are locked.
I personally would start by installing a new phaser. It wouldn't suprise me if it is stuck in full retard or something.
classix_stang289
New Jersey
Any TSB's available from ford?
ZmanM3
The Evil One
Jackson, NJ
How is the oil pressure? I know that the phasers are activated by oil pressure so I'm wondering if something is up with that. Ohh, I'd also like to see more info on the 51 with a 3v.
07calspecial
Lillington N.C.
My cam installer actually found the spring in the phaser was broken and that's what locked it in full retard. This guy is very versed in 3V technolgy, and even he said it took him a good while to find it.
Houston
Thanks to all for the feeback and info, I will keep you updated with my findings as I tear into it. Still tryn to finish some stuff up at the shop so I can take a day off to go pick up the car and start diagnosing.
Ill post up some pics and info about the 51 with a 3v in the next few days.
irishpwr46
Official Site Vandal
NYC
well it turns out my engine was fubar. the vct is oil driven and adjusts according to oil pressure. put a pressure gauge on and see what your oil reads
Dallas, TX
How did this turn out for you guys? I'm having the same problem, same codes. In the Autozone parking lot, replaced one VTC solenoid and the MAF, cleaned & disconnected/reconnected everything possible, & reloaded the modded and stock tunes, but the problem didn't go away.
The symptoms are similar to what has already been reported in this thread. At cold start, the engine is fine. As it heats up, +100 degrees, it surges and idles down low and then runs rough with tapping coming from the valve covers. It sounds like it has cams with a mean lope, but mine are stock. Power is weak and I have to give it a lot of gas to get the RPMs up and get it to move. There is a gas/foul smell and carbon deposits coming from the exhaust.
I pulled and checked the VTC solenoids by connecting them to the battery. They click and behave similar to the new one.
With a mechanical gauge, the pressure reads 50 psi at 2000 rpms. I've read in the Ford specs and Haynes that it should be at 75 at 2k rpms. It idles at less than 10 psi after warming up, but 50-60 or so at cold start.
I had it towed to my place, and I'm in the process of replacing the oil pump with a Melling 10340 now. One question that I have about the Melling is that it came with a 60 psi relief valve spring and an 80 psi relief valve spring. The instructions that came with the pump say that 60 meets that stock specs on the 4.6. I called Melling and the tech said to use the 80.
Any advice/help would be much appreciated?
AutoXRacer
Florida
I would also like to know the end result on your issue... As my stock 4.6L engine crapped out on me too. My cams spun dry due to a failed VCT system.
How did you guys pan out?
NickS
slow3v
Wow you guys are making me glad I traded in my 05 GT with 98k Friday. I romped the heck outta that thing, spun it to 6800, took it to the track, had fun on the street, etc. VCT didn't always sound happy (loud clack-clack-clack under hood when warm).
Seeing you guys' cars like this makes me sick, I feel horrible.
