Greetings from Scotland,
I need some serious help and I hope you folks can help out.
I own a 2005 GT Auto with 55k on the clock.
I bought it in Aug 2010 with 30k and it was awesome. Other than a C&L street CAI and SLP's, she was stock.
She did have an engine check light on which the seller advised me was due to the car running lean due to the C&L.
She was fab. The roar was addictive and the performance outstanding-I'm sure you all know what I mean.
In April 2011 she needed a new battery.From that moment on she has been problematic. Instead of induction roar and speed I ended up with a car that sounded like a hoover with lethargic performance.
She just sounded blowie(?) and bogged down!!
She still started, stopped and generally was ok but nowhere near as good.
After some online research I bought a Diablo Predator with the intention of tuning in the C&L. I used one of the canned tunes and things improved a little but nowhere near as good as before.
Trying to get that magic back I've tried cleaning the mass air sensor, swapped the C&L for the stock box,cleaned and ultimately replaced the throttle body. All to no avail and as time has went by the car has got steadily worse.
Note that after putting in a canned tune (85mm Universal CAI) I have had no engine light.
Further online advise resulted in me getting in touch with Doug at C&l Performance. I got the three tunes; race,perf and torque.
The car seemed a little better; the induction roar was back but I felt the car was holding gear longer than it should and whilst coasting the car would change down on its own. After a couple of days the car would return to poor sound and performance-it's like the car was rejecting the tune after installation. At this stage (after car "rejected" tune), the car didn't want to go above 2000 revs.
I did note that whilst loading the tune, the dash goes through all the warnings until ultimately at 100% loaded, the display says "failsafe mode" and "engine temp warning". Is this normal? When properly loaded, there is no warnings on the display.
In the past week I've replaced the battery, reloaded the tunes several times,cleaned the MAF and still she is lousy.
Today, after a long run she didn't want to go above 2000 revs(unless I used kickdown), wouldn't change down after pushing the pedal going up hills and just feels very heavy!!
Again no engine check light!!
In summary;
She starts ok
Idle is fine
Stock box makes no difference
Maf has been cleaned several times
Throttle body is fine
Emmisions are fine.
There are no exhaust or vaccum leaks.
No undue smoke.
MPG is fine. 30 today on a good run
Kickdown is fine though I'm sure she backfires
I've also noticed from a standing start with a gradual acceleration (not flooring it), she's in 3rd gear before I hit 30mph. is this normal?
In the next week I'm thinking of replacing the MAF, changing the plugs and after that I'm clueless. Throttle body sensor?
Over here in Scotland there are no garages with our car on there diagnostic list so it can't be plugged in anywhere!
Plus remember, there is no engine check light.
So, what do you think is the issue?
This is really grating on me and if I don't find a solution she's going for a bargain on ebay.
Thanks for reading
In summary;
She starts ok
Idle is fine
Emmisions are fine.
No undue smoke.
Thanks for reading
