Horsepower67
- Joined
- May 1, 2014
- Posts
- 14
- Reaction score
- 0
UPDATE:
Low, weak idle problem solved, and most of the weak running situation cleared up
I started questioning whether I had reset the ECU properly, so I went through the steps very by the letter
1. Reflash the tune to stock
2. Disconnect negative terminal of battery for at least 30 minutes (I suggest 1 Hour)
3. Here's the critical one I messed up; crank the car and let it idle until it reaches full operating temperature, and then continue to let it idle for another 3 minutes. This means you cannot touch the throttle at all, and must wait for the cooling fans to kick on. My car has a heavily upgraded cooling system, so in 72 degree Los Angeles weather with the hood down and zero frontal airflow, it took about 27 minutes of idling for the fan to kick on. At this point, most instructions say give it at least another minute of idle time, I suggest three minutes.
4. Turn on the A/C, allow to idle for at least another minute. Again, you cannot touch the throttle, and I gave it three minutes of idling. Idle should noticeably normalize in this time period.
5. Turn A/C off, allow to idle another minute, then take the car for a drive in varying conditions.
This resulted in a better crank than I've had in a long time, and a normal, strong idle with and without A/C. After the ECU learned a bit, the engine also ran much stronger.
The bad news; p0155 still came back. Last resort will be a new Motorcraft DY1039 O2 sensor before taking it to a shop.
Still love to hear your ideas as I will have the weekend to troubleshoot again
