Help with cooling fan temp settings!
golkhl
Las Vegas, NV
Just installed the 2013 GT500 SVT cooling fan(thanks steve@Tasca) on my 2008 Bullitt, and need to know what temp settings I should be at for the low and high speed fan settings. I have the Roush TVS phase 1 kit installed and the Vegas summer heat is brutal. I used my SCT X3 and adjusted the low speed fan to come on at 204 and the high speed fan to come on at 214. Please let me know if this sounds good. Thanks for the help.
Like mentioned, low speed temp should be around your tstat rating ie 192 if its an 07+ and high speed should be about 10 degrees higher.
golkhl
Las Vegas, NV
When warmed up car runs at 195, so if I set it at 195 for the low speed and 205 for the high speed I should be good to go. Thanks for the help.
