Help with intercooler pump wiring
stanglifemike
aka boostedbanana
Douglasville, GA
I just installed an intercooler pump from the 03-04 Cobras on my 06 GT. I also bought the pigtail connector for it. I need to know which wire is ground and which is power? One wire is going to connector labeled ET and the other wire to connector labeled UTA. Thanks in advance :beer:
MLC40
Naperville, IL
I have that pump and pigtail on my car. If I remember correctly the pump is marked + - on the back and one of the wires was black. The black one is ground. I know I have a pic of this but I am at work.
stanglifemike
aka boostedbanana
Douglasville, GA
Thanks for the reply. That would be great if that was the case. Unfortunately both of the wires are black and no - or +. Just the letters that I mentioned above ET and UTA
MLC40
Naperville, IL
Ok, I was wrong. The pig-tail has two black wires. I hope these pics help..
stanglifemike
aka boostedbanana
Douglasville, GA
Yea, I have the same thing sitting in the garage right now. I just need to know which connector is power and which is ground.....
MLC40
Naperville, IL
Look at my second pic, see the key on the pump? My pump was marked with +-. Since the connector is keyed you should be able to figure your out from my pic.
