OK to start with, I blew all my teeth off the ring and pinion gears doing a 5500 launch drop. They were motive gears. So I ordered FRPP 410's and had them installed.
Here is where we need some help.
My mechanic installed them and he put the car back together and called me saying that its not ready cause he is getting a noise coming from the rear, you can really hear it when you push the clutch in at like 35 mph. He took it apart and shimmed it up differently this time. I think the first time was .006 and the second time it was shimmed to .014. This is where it is at now.
He put it back together and it is still making the noise. I put like 300 miles on it and it still makes the sound. The driveshaft feels loose, but the pinion isnt.
I took it out on the parkway and at 70mph it makes an annoying whine. It is so much louder than my motive gears. Something is not right.
Im looking for any suggestions on this. He took it apart and replaced the pinion seal and we are stuck now. He is also waiting for a tool to measure hanging in lbs to tighten the pinion gear before it moves. Can this be the issue? He as done plenty of them so I dont think so, but maybe.
