bumblebee06
Speed Demon
After doing it on Randy's car i thought there needs to be a write up on this. I put together the best thread i can but can answer any questions that may be un clear.
you need to take the fog lights and shave off the inside top bracket.
you also need to relocate the horn as it will get in the way of the fog lights now. unless you decide to mount them closer to the outside.
then get some small 1-2inch l brackets with some nuts and bolts from lowes.
once thats done you need to drill holes on the outside of the hood latch on the inside of the grill.
now not 100% sure about where they are drilled but this is about a close as i could guess. my suggesition is line up the l brackets mounted to the fogs and see where the hole lines up.
once you have the holes drilled then attach the exsiting fog light top bracket to the l bracket with supplied nut and bolt, then attach the l bracket with the fog light to the hole drilled in the body of the car that was drilled.
once all thats done should come out like this
or further apart like this
If you choose this look above you do not need to relocate the horn or cut off one of the fog light tabs.
