Brick
I'm midway through my hot rod cam install on my 2005. I've only worked on the driver side so far... haven't touched the passenger side.
I had trouble getting the driver side phaser back on the new hot rod camshaft. Like an idiot, I pulled out the wedge to try and get a little more slack to work with. I was able to get the phaser back on, but I thought I felt the the chain possibly jump a tooth at the crank sprocket.
Knowing the passenger side is still good... is there any way to check and be sure the timing is correct on the driver side without pulling the front cover? I read somewhere that the timing marks should line up every 37 revolutions of the engine... could that help?
Thanks for any advice or experience.
The picture below is the driver side phaser as it is now, with the crank pulley at 6 o'clock, and the timing mark on the crank pulley at 7 o'clock.
