05stroker
Never enough power guy!
Okay so I have a HSW wet kit on my car. I am spraying post MAF about 6-8in from the TB. I have a HSW Microedge controller and need to know what rpms to spray at. I am spraying on top of 23 psi and have a screen shot below of what my shift points look like. The car is an auto so I do not lift off the gas unless I spin. I will be spraying a 75 shot for now.
If you look at the screen shot below, you can see I shift at 7000rpms and only fall back to 5800 on the shift. This is where I need advice on where to set the controller at. I have been told that I don't want to spray during a shift, is this true?
I would like to spray from 4000 rpms to 6800 in all three gears. Does it need to be set at 5900 - 6800 in second and third?
Any other settings or advice on the Microedge controller?
This is my first time to use nitrous, so I have may questions.
