I need help installing a Zex Nitrous system
MustangMarc
I’m not sure on how to install it this
Is my first time ever doing this
did it not come with an installation guide?
you should post the system you have, there are more than one type, some details would help you get answers.
MustangMarc
It’s the system with the Nitrous Management Unit the part number
Is 82034
Marble
Shasta county CA
The instructions are pretty self explanatory. If you get stuck, come back and ask.
Put your bottle in the freezer overnight when you take it in to get filled. Or if the place has a freezer, leave it overnight and they can fill.
Go through the instructions, go get the tools you do not have.
Also, I used 3m double side tape to mount the control box. Worked really well.
RocketcarX
95% of my weight is fuel
Colorado
Pay a quailed installer to take care of it, don't ruin your engine
Where are you located?
groundpounder
Take the thing that looks like an upside-down penguin. Using your right hand orientate it so that its head is to the east. Then with your left hand use some vegan personal lubricant to gently grease your oring. Once it is lubed to mil-spec 11-56-54378, place it on the southeast protrubence if the part. Once that's done, use the above manual to either a) find the page with the associated instructions or b) call the manufacturer's tech support line.
MustangMarc
Which wire connectors go on the NMU? Pictures are videos are greatly appreciated
07 Boss
Sin City
D. Locate the four wires that go to the throttle position sensor. The wires are located on the passenger side of the engine’s throttle body assembly. Using the supplied red T-tap connector, tap into the YELLOW wire. Attach the red crimp-on blade connector to one end of the white TPS Resistor Wire and plug it into the T-tap connector. Attach the other end of the TPS Resistor Wire to the white wire from the nitrous management unit. If the white wire from the NMU is not long enough to reach the TPS Resistor Wire, an extra length of white wire has been included in the kit.
