Sharp07GT
Someone tell me if this is possible. Or should I just do a D1SC and a forged stroker with cams and heads? Which is more cost effective?
fly wheel HP or rear wheel HP? you have the following options:
1. wait for the newer 2011 5.0, it should do better N/A because its bigger and more efficient.
2. buy an LS3/LS7 Engine and do the conversion, it would net you over 500 whp on manual cars.
I agree that its too much of a hassle, but we have done conversion to older mustangs with gen3 ls1 PCM and painless wiring. Car drove fine and they make 500+whp with LS7 and unlocked TH350 Trans. I just think its too much to ask 500+whp N/A. Big block engine will cost more than LSX as you have to run a standalone ECU if your gonna use fuel injection. LS-conversion with LS PCM and tranny is less hassle believe me.#2 is just way too expensive and difficult trying to marry a GM\drivebywire engine into an s197 doesn't make sense to me. might as well put a big block carburetor motor in it and be done with it.
i can tell you that my engine ( read car of the month for jan 2010 here on the forum) makes 550+hp at the crank and a very conservative 421rwhp with a high stall converter and auto trans but doing things this way isn't cheap and never will be. you have to want to do it NA or you can't justify it at all.
check it out
http://www.s197forum.com/forum/showthread.php?t=26603
Think I'll just blow it, should be more streetable that way too. Thanks for the help guys!! BTW, It ran a best of 8.49 @ 86.8mph in the 1/8th before I had the Steeda Pulleys,Line lock, DR's and dyno tune!! I've done some weight dropping since then, Rear seat delete-40lbs, Steeda lower radiator support-31lbs, Removed all audio equipment- 23lbs, Spydershaft-23lbsand removed spare tire-25lbs?Now if I can lose about 100lbs I'll be doing good!! LMAO,
What kind of rear seats do you have that weigh 40lbs?
I saved 40lbs with the delete kit dude.
Even if you pull the seat belts and all of the hardware, I don't think you can shave 40 lbs. 30, but not 40. Plus, the delete kit is going to add some weight back.
450-500 hp at the wheels, NA, stock 4.6 displacement... not happening. A twin screw at 8 or 9 PSI will do the trick.
I agree about the power, I don't think there is much more N/A power attainable if at all than Hurricane Performance's shop car which made 440rwhp, unless it's a 5.4 setup like Ron's.
Unfortunately if you staying all motor, then you will spend some coin. We believe we can get a few more out of our shop car, but I wouldnt expect to see much , much more
To build a motor like the one in out car would be costly but wouldnt be outrageous since we have done it and know exactly what to do. Would be it easier to get a blower. I would say yes, so at that point it all becomes give and take, and truly knowing what you want!!!
The rear seat delete said it would drop 40 lbs http://search.americanmuscle.com/search/Generation-2005-2009--keywords-rear_seat_delete_kit
