Ghost: Last year, I had NO cooling problems, and want to keep it that way, DESPITE a fairly radical re-build of the front part of the car...
Background: The Steeda competition fascia that I have been running was deemed to assess a whopping six points (NASA TT), putting me way over budget for TTB, so that had to go... That means a stock front (GT, not CS) fascia, which in turn means that I have to re-design my brake duct routing. I CANNOT run them in the corners of the lower grille, since one of them is currently housing an oil cooler. I can't really mount them in the blank space below the turn signals, due to obstruction (D/S is where the remote-mounted oil filter lives, and P/S has a coolant overflow catch tank and transponder in the way). The POS stock P/S cooler is in the way for duct routing for a more central location in the lower grille, but I have a solution for that... FR500S power steering cooler! It looks like that will mount up top, right across where the horns live stock, but those are not that difficult to relocate. That would put my ducts in the "middle" outside panels of the lower intake, where they will most likely rob a bunch of air from the radiator, and the ducts running into a 90* elbow on the back of the intakes will block more of that area. Add in the P/S cooler up top, and I'm really starting to potentially choke the airflow pretty badly. I am running the stock radiator, and stock oil pan, but: 1) with no airflow, depth of the radiator will only delay the inevitable, and 2) my oil system capacity is upwards of 9 quarts (stock pan, relocated filter #FL1A, oil cooler, thermostatic flow valve, and Accusump). Last season, with a wide-open lower grille inlet, I was running around 205-210* coolant temps (measured in the side of the block cooling jacket), and max of 220* oil temps, just barely above the point needed to flash condensation out of the crankcase (measured at the oil pump outlet, not the pan). My fear is that by blocking the P/S corner of the lower grille (TT rules are a little obfuscated on what exactly costs what), plus the bulk of the two "middle" panels with ducts, and then adding a fin/tube cooler up top, I would robbing enough airflow to create issues for myself.
My overall thinking would be to run an essentially "open" grille (have to keep the shape to meet the rule book) would buy me a bunch of that flow back, and allow me to "tune" the airflow rate by adjusting the size of blockoff panels behind the grille. In essence, it's MUCH easier to cut down on airflow than it is to add it. The fact that it would also potentially shave a bit of weight high and forward is also a bonus. I will also freely admit, that I would like the car to look at least reasonably nicely put together, so a decent looking but functional grille would kind of cap off the front of the car.
Honestly, I'm staying away from the radiator/oil pan primarily from cost considerations... With all the events I want to run this season, just keeping myself in tires will be hard enough. The extra kilobuck or so up front is just not in the cards.
Duster: Believe me, I gave that some thought, but the "missing parts on a racecar" theme (deleted fogs, with mesh covers) just doesn't sit well with me. I'm still not trailering this year, so I drive to/from the events, and if the car at least looks decent I'll have a SHOT at getting past the state troopers, even with the car lettered up and towing a tire trailer behind. Also, I don't know if there's enough area I can open up in the webbing to give me the flow I'm looking for. That gets back to the "easier to restrict" concept. I should probably put up a "pre-season buildup" post with the gory details and pix of all that's been going on.
