Line lock and ABS
OhhFiveGt
Long Island
I think I got it figured out I rebleed the whole system and the abs pump itself and now it seems to be holding I think some air got trapped in the pump
s8v4o
When I did mine I had to get a pneumatic bleeder, especially because I did it all by myself with nobody to push in the brake. When the system is cracked open before the ABS unit it can be a real PITA to properly bleed the system afterwards. Line locks that are installed post the ABS unit don't require as much effort.
NUTCASE
when I did mine The fluid in the system was old, so I just bled until I saw new fluid comming out. Guess that's why I never saw that problem.
OhhFiveGt
Long Island
That's what I had to use also. Regular bleeding I wasn't seeing a single bit of air or anything seemed fine. I hooked up the vacuum bleeder and it forced out a decent amount of air so I have to assume it was trapped in the pump.
I'm just happy it's figured out now this was killing me.
