Line lock question
martinr69
Fraser Mi
Ok I installed line lock last night on my 2005 mustang. My question is this are the front wheels suppose to be completly locked? The reason asking is I clicked it on last night and was moving slow. Now I don't know if I bleed the brakes right or not. Or if its user error and not using it right lol..
But I could use some help
94tbird
4R70W FTMFW
completely locked. rebleed the brakes. if that doesnt work then you may have solenoids that cant handle the pressure or are leaking internally.
martinr69
Fraser Mi
ok I have been reading that some are roll line locks and some completly lock. I have the SLP line lock kit do you know what type those are and do i have to bleed the brakes with the car running
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
No; there is a bolt on the backside of the brakes-8mm I think-that you loosen, have someone in the car push down on the brake pedal, pump the brakes until you have brake fluid squirting out, have the person in the car hold the pedal to the floor, close the bolt and repeat.
No need to have the car running.
Start at the passenger side rear brake, then driver side rear, passenger front and driver side last...make sure you have a new bottle of fluid with you as you will go through a good bit when bleeding the brakes.
martinr69
Fraser Mi
ok now when I use the line lock do i push the brake and flip the switch or flip the switch and push the brake? sorry for all the dumb questions
since it's not clear to me. when you
you pumped the brakes once or twice and held the pedal down when you engaged the LL?
martinr69
Fraser Mi
ahh no I just engauged the line lock. didn't pump the brakes once or twice first. That maybe the issue with them not locking. I never used line lock before so this is the first time..
martinr69
Fraser Mi
I thought just flip the switch and it locks didn't really tell you how to engauge it just how to install it lol.. what an idiot i am lol
well, the solenoid engaged fine. but there was no pressure in the lines to keep the calipers locked against the rotor.
pump the pedal once then press and hold, flip the switch, release pedal, press pedal (should be hard), report back.......
tech thread of the day.......
yes, yes you are......... :poke:
SteveP
Modular Specialist
Boynton Beach, FL
just about fell out of my chair. lol
Boozshey
Tampa
oh my hell, this is one of the funniest threads I've read on our forum in a long time!!! hahahahahahahaha
Greg Hazlett
Official Vendor
Chesapeake, VA
Funny thing is the OP was right...they tell you how to install it but not how to use it and I learned the hard way as well and had to ask people at the track what I was doing wrong so OP, you are not alone!
