Todd thanks, I can get one new for just shy of 250 so I will be doing that.. Joe you are correct I spoke with ford today and those are the engineering numbers, the part number you have is in fact the correct part. I have the ability to program it so that is not a problem. i appreciate all the input... My poor car I bought new in 12/04 it now has 5000 miles on it has been sitting .. and as we know sitting causes issues, I had water intrusion on the sjb that is why I am replacing it, I am unable to arm the alarm because it sets a code saying the hood is ajar so I checked things out and found that It has water intrusion that I knew about and fixed last year. I decided to start to drive it , so I put in some mutha thumper cams and vvt limiters , some axle back and a tune. I now need to replace the tires , wiper motor ( also had water intrusion has no washer function) and the driver's seat lumbar ( crunched and stopped working lol ) After I get this one up and running I may get my fox body going.. 92 with a 306 , 185 afr heads, procharger, all suspension done, 6pt cage , eec tuner the list goes on and on, that has been sitting even longer , I just don't have the time to play with them like I use to but now I am getting older it is time to play while I still can..
