Lowering Springs for rear and drag racing.
badnews
North Florida
Anyone have issues after lowering the rear of the car for appearance vs stock height? The suspension is working great, all I have is BMR upper arm and lower arms. Nothing else. 1.6x 60 fts last time out. With a 27 inch tall tire, the car still has a decent gap in the rear though.
Thoughts?
BMR Tech
Traction Vendor
Official Vendor
Tampa, FL
I prefer a drop on this chassis, when aiming for good straight line acceleration characteristics.
I prefer to use a lowering spring that is in the 150-160lb/in range out back, and similar up front (130-150lb/in up front)
Alot of people will even use a rear coilover spring.
I am not sure what exactly you are asking, but, lowering the car will not hurt straight line accel (traction) if you have the appropriated supporting mods. We engineer our parts around OEM and our Lowering Spring heights.
2011/5.0
Iowa
Sounds like he has more gap than he expected in the rear. Not sure of what would cause that
badnews
North Florida
You hit it on the head. I want to figure out what to do to get rid of the gap in the rear but did not want to mess up the suspension geometry where I would have traction issues I currently don't have.
I'll call you guys when I'm ready to get the right stuff to do it right. :bravo:
2011/5.0
Iowa
I ran the bmr sp009r and they worked well at the strip
quiksilver15
Houston
With lowering springs, a set of relocation brackets will put your LCA right where they need to be. You've already got the UCA covered, should hook just as good as your current setup.
Iowa
Hopefully you have the adjustable upper arm so if you lower it you can adjust your pinion angle. And of course you need the adjustable panhard bar to recenter rear
