MOC I did the FRPP drop without a panhard bar for quite a while. Pretty much until I found one used in the for-sale section. As others said, with stock wheels it's hardly noticable. You'll see it if you look for it, but others wont even notice. I now have an adj UCA and an aluminum DS on the way, and if you have that sort of thing, yes you need the adj PHB, but you can get by without it for quite a while. I noticed no abnormal tire wear or adverse effects on steering or handling. However once the PHB was on and adjusted correctly it seemed that the rear end grabbed quite a bit better.
