LPW Differential Covers and CHE Axle Braces
Kevin@PMP
Concord, NC
LPW Extra Low Profile Aluminum Differential Covers for $150 SHIPPED!
We are also offering a special price of $330 shipped for a LPW cover and CHE axle brace for '05+ Mustangs.
This differential cover works WITHOUT relocating the upper panhard bar mount saving you about $70 compared to other covers and the relocation bracket.
To purchase just the LPW cover go here: LPW Cover for $150
To purchase both the LPW Cover and CHE Axle Brace go here: LPW Cover and CHE Axle Brace for $330
Benefits of the LPW Cover:
LPW extra low profile Ultr-Pro covers offer maximum chassis clearance and measure only 3 1/8" tall. They are the lightest support cover on the market.
Both Ultimate and Ultra-Pro heat-treated aluminum covers strengthen the rear housing from case distortion, preventing increased side bearing clearance and ring gear deflection. LPW's exclusive adjustable grade 8 load bolts prevent the bearing main caps from movement and possible breakage. Maintaining proper pinion depth & gear backlash results in maximum gear life and performance.
LPW offers ARP main cap stud kits for most applications.
* Fill and magnetic drain plugs
* Additional clearance for billet main caps and low gear ratios
* Increased fluid capacity and reduced operating temperatures
* Includes instructions and proper cover mounting bolts(including metric if needed)
* Simple bolt-on installation
* Made in the USA
* LPW cover clears the factory or aftermarket Panhard Bars with out relocation
* Prevent twisting and bending of your axle housing allowing for increased traction and durability.
* Fits the 2005-Current Ford Mustang with the 8.8 rear axle
* Clears stock and aftermarket exhaust without modification
Benefits of the CHE Axle Brace:
CHE 8.8" Axle Brace prevents twisting and bending of your axle housing allowing for increased traction and durability. CHE Axle Brace also works with BMR and CHE Lower Control Arm Relocation Brackets.
LPW Cover
CHE Axle Brace
CHE Axle Brace and LPW Cover
LPW vs Stock Cover to panhard bar clearance.
94tbird
4R70W FTMFW
now THAT is a hell of a deal. Keep em coming guys!
S197 GT
PINK Casting Director
Nor Cal
Yeah buddy!!! I've been waiting for these to come back out on sale!
Great pricing guys, as always! :trophy:
V
VSOP
Guest
anyone have the brace and a run a lower profile tire like the 25.5" MT's..? I wonder about clearance, how far below the pumpkin does it hang.. Here in tampa the road SUCK...
Kevin@PMP
Concord, NC
It only hangs below the pumpkin by about 1". It would be almost impossible for it to hit the ground.
Geos05GTvert
GA
Kevin,
Will the axle brace install on the stock d-cover with out issues or do I need to get the cover as well?
