Rob@Evolution
$425.00 - Slightly Used Ford Racing 90mm Throttle Body and Boss 302 Spacer
M-9926-M5090 - M-9926-M5090 - Ford Racing 2011-2014 MUSTANG 5.0L 90MM THROTTLE BODY
Retail - $630.00
90MM Billet Aluminum Throttle Body
Fits 2011-2014 Mustang GT/ 2012-2013 Boss 302 with stock 80mm throttle body
CFM Rating:1132cfm; with adapter 1101cfm (stock 80mm throttle body: 913cfm)*
4" diameter leading edge larger than stock throttle body - requires use of 4" ID silicone hose adapter or reducer
4" air inlet tube is recommended for maximum horsepower
When using factory 3.5" diameter air inlet tube the molded rubber throttle body hose must be removed
Ford Racing's performance electronic throttle bodies are for vehicles equipped with electronic throttle control (ETC)
Includes jumper harness
Does not include calibration, calibration required.
All Ford Racing ETC throttle bodies feature:
All factory sensors installed - no need to tear apart your original throttle body
Calibrated for idle air flow using the same procedure as production throttle bodies
Throttle body features CNC'd Ford Racing logo
Precision billet construction with tapered inlet for consistent high flow
Validation through hundreds of hours of dyno, racing, and street performance driving
Polished aluminum for great looks
M-9474-M50B - BOSS 302 90MM THROTTLE BODY INTAKE SPACER
Retail - $50.00
Fits 2012-2013 Mustang Boss 302 or 2011-2014 Mustang GT with Ford Racing Mustang Boss 302 Intake Manifold M-9424-M50BR.
Spacer used to adapt 90MM Billet Aluminum Throttle Body, M-9926-M5090, to 2012-2013 Boss 302 Intake M-9424-M50BR
Retail - $630.00
Retail - $50.00
Retail - $630.00
Retail - $50.00
Retail - $630.00
Retail - $50.00
