maf issues?
5.SLOW
missouri
My car a/f is jumping everywhere is the maf sensor only thing could cause this issues? Thanks
This is on my 07 with cams
lskiller
Not necessarily. Does it do it at WOT, too or just cruise? If it's just cruise/idle I'd check all wiring and if that looks good, replace the front 02 sensors.
mach828
Albuquerque, NM
What do the short term fuel trims look like when you datalog? Does it do it immediately after start up or does it take 60 seconds or so before it happens?
5.SLOW
missouri
Well put new 02 sensor in and still does it and wiring look ok
It does it sometimes bad at first then it might settle down then act up again. It weird and short trim don't look bad.
