Test-fitted the headers and k-member, and measured for hood clearance. It looks like the engine will fit under the hood that I already have. Wo
What mounts are you using to connect to the K member?
Wow, that pan and rack "just" fit...Looking good.
Thats how I set everything up also---I moved the engine as far back as the oil pan would allow with the flaming river manual rack to see what had to be done engine mount wise and trans mount wise.
You will be glad that you used that spacer behind the throwout bearing slave cylinder. I didn't think it was necessary when I swapped my 5.4 DOHC and an Exedy clutch to handle it and sure enough, I have to almost get the clutch pedal to the floor for full engagement and as soon as that pedal is leaving the bottom of its travel, we are moving. It is very difficult to shift under power (when G-forces are pushing you back and you have to mat the clutch pedal). Now when I have time to pull the trans again, I have to put a freakin' spacer in.
Nice swap too.
Excuse my ignorance....why is a return fuel system needed with a carbureted motor?
did i see that right? there's a slip joint at the back of the transmission, and another slip joint in the drive shaft itself at the rear end? is this your transmission in the picture, and it takes a slip joint, right? and you have another slip joint on the other end of the drive shaft?
