skwerl
tree hugger
Shane, I believe he means you don't want to take the big gold ring off the red plate. It's held together with 12 point bolt heads so your six point sockets wouldn't fit anyway.
The pic above is incorrect. You do not want to remove the gold ring. The bolts circled above are ok to r&r.
Do not remove the gold ring bolted to the flywheel.
Btw, that Magnum safety loop may not be compatible with your MAC install. I could not use it due to interference with my exhaust.![]()
Hmm... that is interesting. Must be different for the TR6060 then, my flywheel came without the adapter ring installed. The only portion I thought shouldn't be messed with was the floater plate. I may be wrong, but could you explain the reasoning behind not removing the adapter ring?
Edit: nevermind, I read the instructions for the modular install and see that it is different than the TR6060. Disregard my comment, sorry for the confusion!
yes I checked with tasca and jpc today, looking at $220 for the oem slave, I may of confused the pricing when I replaced my master cylinder. I believe I'm going to try the 13+ plus gt500 master cylinder. Only $75 from tasca. Supposed to move more fluid quicker for quicker clutch release.
NO!!!! The 2011 and newer GT500 is a totally different slave and will not work unless you use a GT500 clutch!!!
using the gt500 master cylinder, not the slave cylinder. From what I've read on another tread people on here have used them with good results
What is the difference between the GT and GT500 master cylinder?
Isn't it a PITA to R&R??
It's not that bad. 45-60 minutes. Just know that the pedals have to be unbolted and don't spend a bunch of time trying to get around it.
I've always removed the adapter ring from the flywheel. The clutch kit itself comes without a flywheel so the point is mute. The torques need to be followed though. IMO the part not to remove is the floater plate. There is a set of instructions floating around that say to remove it and verify the shims. That's an old set of instructions and iirc they were for the gen 4 Camaros.
All the McLeod issues stemmed from bad machining of the gold ring...nothing wrong with the floater.
There are no shims in the floater...shims are used with the gold ring.
