HellsBells
620/677
Does McLeod make an aluminum flywheel?
I run the RXT with McLeod's aluminum flywheel and it bites hard with no issues so far with over 5,000 miles.. I do get that buzzing sound from having the alum flywheel and alum 1 piece drive shaft, but i only get it in 4th gear if i go under 1800rpm.. Other than that it revs fast and never slips, clutch pedal pressure is butter like my old Audi S4.. Can't go wrong with one of these clutch flywheel packages, personally i would not mix and match to save a couple dollars.
What are you guys using for slaves on the rxt's? Stock or Mcleods slave cylinder. Have you guys had to shim?
Where are you guys getting your OEM slaves? Whats the best price? I could of swore I bought one for a little over $100 awhile ago but every where I'm looking they are all around $220
I paid $200 for mine. The ones less than $200 are not OEM Ford. But maybe from the same manufacturer, but I am not sure.
I'll pay extra to make sure its an OEM Ford part when it has to be.
I've read of not so good reviews on aftermarket units.
