UltraKla$$ic
PERENNIAL WAXXER
Here is the youtube video from MGW regarding the Gen3 RACE SPEC shifter:
I started taking out the older MGW shifter, making a way for the new MGW Gen3 RACE SPEC shifter headed my way. Here is a pic of this behemoth of mechanical engineering:
First let me say you better pray you have small hands. Fat handed folks are going to be in a bind. LOL
You will HAVE to lower the transmission to get to this 10mm bolt here. NO OTHER WAY AROUND IT!!!!!
I used and old scissor jack and a piece of 2x4 to shim the transmission and hold it in a lowered position while I removed that bolt.
To get the little noise suppressant "cup" out of the shifter linkage arm I used a small screwdriver and pryed/worked it out from the BOTTOM of the cup, like so:
You can do it like the MGW video describes by grabbing it by the little holes but I'm gonna say there are going to be ALOT of destroyed plastic cups by doing it that way if you do not handle it tediously like MGW suggests. . The way I did it kept the little cup from tearing along the thin plastic that runs across the top of the cup that was suggested for prying on.
Cup is out with ZERO evidence of distress on the thin plastic around the holes:
My shifter will be here Monday so I'll finish the install then.
already have my fuel system ready too
