Mikes first home!!
mikeysgt
Bakersfield, CA
See that's my thing. I wanted to do wood floors for the entry way and than the dining and living room which are off to the sides. But, the budget is only going to allow for laminate right now since a lot of other stuff needs to be done. After a lot of back and forth I decided to just carpet those areas since the house needs all new flooring anyways. I figure in a couple years I can buy real world floors or maybe engineered.
yeah it's a tough choice man. I almost decided on returning the laminate and just recarpet the living room and hallways. then in the end I decided we're going to go through with the laminate floors except we decided to keep the tile in the kitchen and dining room for now.
I'll be starting the laminate pretty soon once the garage is done. then sometime next year I'll retile the kitchen and dining area with nicer 18" tile.
I might start ripping out carpet tomorrow on my day off and start the laminate this weekend. the money I saved from not doing to kitchen and dining area I'll use to finish off the fireplace corner wall with stone.
NastyStang113
Made in U.S.A.
Central Florida
Without a doubt. Nearly all of the choices I'm making are hard ones. I'm doing it once and it's going to be right. I've been researching the shit out of every single thing I'm doing and buying. I've got a lot of work cut out for me. I'll probably create a build thread like yourself. I close on my house on the 15th or before, can't wait.
HOLYWD
S197 Junkie
If you run out of space you can leave the stang at my house , I have plenty of room ! :thumb2:
mikeysgt
Bakersfield, CA
I've been stuck watching the DIY network and man I keep getting ideas. after the floor project I'm moving straight into building a bar/patio cover on the cement slab along the back of my house. seems like a pretty easy job to do
mikeysgt
Bakersfield, CA
so today we got another layer of compound laid out across the seams in the garage. one more then we can get finished by hand texturing the walls before primer and paint soon.
decided I'd start ripping out the entry way tile and start cleaning the floor up for the laminate flooring since I'm pretty sure we'll be starting tomorrow night and through the weekend. tomorrow morning I'll finish up the rest of the tile pieces and start ripping some of the carpet out also.
first time ever ripping out tile. seems like a pretty easy cleanup job.
mikeysgt
Bakersfield, CA
woke up 40 min ago and back to work I go! damage is done. no turning back now haha
update: all cleaned up and finished with tile demolition. now ready to start cutting away carpet rolls.
mikeysgt
Bakersfield, CA
yeah I'm putting the wood where the tile used to be in the entry way. not sure what you meant by the thinset but here is a pic with everything cleaned up. didn't bother removing every bit of paper since the underlayment will sit flush on top of it. just need to remove the baseboards now.
just got back from the gym so it's back to work and time to start ripping out the carpet
mikeysgt
Bakersfield, CA
a couple more hours of work and the carpet is almost out. just one more hallway to go
don't think I ever posted our two first pieces of art to decorate the house. bought on sale at kohls for 72 bucks for both. on sale from 100 each. I think it goes perfect with the red walls
HOLYWD
S197 Junkie
paintings are sweet !
floor is coming along bud !
mikeysgt
Bakersfield, CA
had a feeling that's what you meant by it. I just finished up with removing all the carpet and padding along with the baseboards. tomorrow I'll go over the house and clean it up real good before starting the install tomorrow afternoon. feels weird not having anything but cement on the floor right now but can't wait to see it when I'm finally done
mikeysgt
Bakersfield, CA
about halfway through with laying down the 2 in 1 foam underlayment. hoping to get it all done tonight and start laying down the laminate flooring asap tomorrow morning.
mikeysgt
Bakersfield, CA
been a loooonnngg day but it's coming along nicely. about 3/4 done and just pretty much need one hallway to go. my legs are killing me and my knees look worse than a t.j. hooker right about now.
