my front right leaks...too bad i bought it second hand..
but the damping still feels good. everything aside, id still recommend it.
It's hard to "feel" one bad damper.
KW's equivalent, the clubsports, have no warranty or maybe it was one year. Either way, they were like $680 for a full rebuild and that's if you don't have worn shafts. That's as cheap as you can get away with that rebuild.
Wow! Seriously? My Penske 7500s (single adj.) were only $330 to service and revalve the pair (+shipping). Was that $680 for all four or just the fronts?
And yes, +1 on finding it hard to feel one bad damper. I had a blown rear Koni that literally had zero compression left in her and (rather embarrassingly) I didn't know until I pulled it for an upgrade.
Best,
-j
And to the OP, I don't know of any serious dampers that don't get rebuilt periodically. I wouldn't throw the towel in. Fronts suck a little when they go out but, rears are super easy.
It was for all four, so about the same as the Penskes. What do you have one the front ?
On a side note, the day I received my koni yellows I got a stop watch and compressed each of them and timed the return on full soft and full hard for future diagnostic purposes ....just incase oil leaking everywhere was not evident.
Eibach is sending me a new dampner.. and I am going to order vorshlag plates.. hopefully this will be the end of this nightmare
