motion delete plugs for 3v 09-10
Ok so I tried using the stupid ass search bar seems it doesn't work
Now I'm just looking for guys who have exp using the motion delete plugs on there 09-10 3v it's a cheap mod it's still a while before I upgrade to a better flowing upper intake
For now it's stock cat delete/muffler delete/e85
And now the weak ass tr3650 3rd gear took a shit well the synchro not the gear lol
Well it would pop up but wen I clicked on the text input it would close the search bar but thank you
roberts
Bonne Terre, Missouri
Take cold air off throttle body. Take all bolts out of intake manifold.. and there cmdp are under intake manifold
Fordbanger
Grand Bay Al.
two options 1.remove 09-10 charge motion butter flies fill and smooth out area. 2. find intake manifold from 05-08 and put it on the car with motion delete plates. Hope this helps. there is very little information in your question besides the title. So I am assuming you have a 09-10. I think someone makes a kit for your model year as well. But the easiest way and best is what I said on option 1. but if you dead set on using cmdp you need a earlier style intake manifold or just buy a frpp intake manifold and don't worry about cmdp.
SNKPWR
Lake St. Louis, MO
He's specifically asking about the delete plugs for the 09-10 manifold.
Honestly you take the manifold off, remove the motor on the back of the manifold, brackets and charge motion plates and bars, then insert the plugs. Not much to it really.
All im looking for is a write up on how to do it and where the little plugs go and where to set the small shafts i have the kit here already just need to put the stuff on
