Muffler Flow Ratings
jroc07gt
its orange not yellow!!
hammond,la
I did some searching and found a list of quite a few popular muffler flow ratings. If anyone knows the flow rating of some more mufflers, please post it up and I'll edit the list.
All muffler flow ratings are with a 2 1/2" offset inlet/offset outlet and measured at 28" H2O
Here goes:
3" Straight Pipe 705 CFM
2 1/2" Straight Pipe 485 CFM
Pypes Violator 453 CFM (louder than the Race-Pro)
Pypes Race-Pro 453 CFM
Magnaflow 436 CFM
SpinTech Pro Street 427 CFM
Borla 427 CFM (not stingers)
SpinTech Sportsman Street 402 CFM
SpinTech Truck/RV 391 CFM
Pypes Street-Pro 349 CFM
DynoMax Super Turbo 344 CFM
Hooker Aero Chamber 344 CFM
DynoMax Turbo 320 CFM
Flowmaster 40 series 273 CFM
Flowmaster 50 series 213 CFM (Jesus these things suck...)
For every 2.2CFM, 1 horsepower is restricted or unrestricted. That means it takes 880CFM (440x2 mufflers = 880cfm) of flow to support 400whp. Of course that is an approximation, it's not an exact science but is a pretty close estimate.
Sound Levels
No Mufflers - 91db@Idle - 103db@2000RPM - 120db@WOT
SpinTech ProStreet - 87db@Idle - 97db@2000RPM - 116@WOT
Hooker Aerochamber - 87db@Idle - 94db@2000RPM - 114db@WOT
Flowmaster - 82db@Idle - 93db@2000RPM - 115db@WOT
Magnaflow - 82db@Idle - 91db@2000RPM - 114db@WOT
cdutchess78
erie,pa
Does the restricted air flow also corelate with how loud they are as well? If not,do you happen to have a chart for that as well? :)
jroc07gt
hammond,la
There is a decibel chart too, I might be able to find that one as well.
Edit: Updated topic with sound levels for the ones I could find.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
As a side note..my car was dyno'd with 300 miles on it with the JLT intake/tune on it and the stock mufflers; had the Stingers ready to install so while it was on the dyno they were installed and there was no increase/decrease in numbers so the stock mufflers are not a restriction.
jroc07gt
hammond,la
Obviously, you don't have enough mods to make your engine flow more air than the stock mufflers can flow. You would most likely have to make 350whp or more to start to see even the slightest gains from changing out the stock mufflers.
I don't have the flow ratings for the OEM mufflers, but I'd have to guess it's at least 375CFM. That would put it at 340whp, so the stock mufflers are more than enough for a bolt on s197.
Edit: On a sidenote, most dynos seem to reflect these flow ratings as flowmasters lose power while magnaflows gain power. Flow rating alone cannot show you everything however, such as: does the muffler come with mandrel bent piping, does the muffler use a chambered design or a straight through design, and does the muffler's tip restrict flow?
The flow rating alone does not tell you if you will pick up power, but it's one more piece of the puzzle that can help you figure that out.
SirKnightTG
Deep in the <3 of Texas!
This is a cool thread.
I find it funny how poorly the flowmasters do given their name and all. :)
I have Boomtubes so I guess they would be about 450 maybe.
jroc07gt
hammond,la
I think the Boomtubes are pretty much a straight pipe with a 4" tailpipe that has some baffling, so it would flow the same as a 2.5" straight pipe.
shatter
White And Nerdy
Northern California
This was taken from http://www.mustang50magazine.com/te...rd_mustang_muffler_comparison_test/index.html
The test vehicle was a 1990 Mustang with a 5.0, built as a 306 with Twisted Wedge heads, Thick Flow Track heat manifold, 75mm throttle body, AFM N-91 cam.
The Borla XS was the best performer, but at over $150 each, out of the reach of most. Next on the top of both low end Torque AND High end HP, is the Magnaflows, and with a choice of coated steel, or stainless.
shatter
White And Nerdy
Northern California
This was taken from http://www.broaderperformance.com/muffler_flow_tests.htm
This is a chart of popular performance and a few stock type mufflers I have tested on our flow bench. These were all the most popular mufflers sold and installed at a local exhaust shop. Straight pipes have been tested and are used to compare these mufflers to "potential" flow of a muffler. When running a performance muffler on the street there are many more things to consider then just good flow. For instance pleasant tone and enough sound reduction to avoid any "unwanted" attention from local authorities. One thing to keep in mind is how restrictive tailpipes are. You can have a great flowing muffler but if your tailpipes are restrictive you may not be getting any gain from loud, high flow, and not to mention sometimes "expensive" mufflers.
shatter
White And Nerdy
Northern California
This was posted on www.fullsizechevy.com which is a truck forum. Supposedly this review was performed by Martel Brothers...
All tests via an independent lab
All tests @ 15” wc
2 “ Straight Pipe 283 CFM
2 ¼ “ Straight Pipe 365 CFM
2 ½ “ Straight Pipe 521 CFM
2 ¼” Typical Bent tailpipe 268 CFM
2 ½” Typical Bent Tailpipe 417 CFM
2 ¼” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ¼” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ¼” Cherry Bomb 239 CFM
2 ½” Cherry Bomb 294 CFM
2 ½” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ½” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ½” Inlet/Outlet Gibson Superflow 267 CFM
2 ½” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ½” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ¼” Inlet/Outlet Thrush CVX 260 CFM
2 ½” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ½” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ½” Inlet/Outlet Hooker Max Flow 521 CFM
2 ½” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 ¼” Inlet/Outlet 138-152 CFM
Standard OEM 2 ½” Inlet/Outlet 161-197 CFM
antonio1988
Redline: 8600rpm
Miami, FL
very interesting read... I have the Magnapacks, which are a resonated straight through design, I'll assume they flow close to the 2 1/2" piping rating?
SirKnightTG
Yep. But I figure the baffling may slow it down just slight. That's why I'd estimate it to be a little under straight 2.5" pipes.
gmantheman
Escondido, CA
Flowmaster A/T just may affect performance. Two of my friends with S197s went to the 1/8 mile strip. Both were running constant 8.7XXX at 81.XXX. The next time at the track one of my friends replaces his stock axlebacks with flowmaster A/T. He was now running 9.1xxx to 9.2XXX at 79.XXX while my other friend was still running 8.7XXX at 81. The only difference was the flowmasters.
