Mustang drift techniques!
Discussion in 'Drift Racing Tech Discussion' started by Schnee197, Feb 1, 2012.
  1. Schnee197
    Schnee197 forum member
    33
    62
    I enjoy drifting my mustang a lot. I use the clutch kick to get tail out at the apex of the corner. I was wondering if any of our more experianced drifters here had any tips for entering the drift earlyer, I have been trying to get the trail braking entry down but I havnt been able to pull it off yet.
  2. BAKnBLK2010
    BAKnBLK2010 Harley Davidson FLHTCI
    3,280
    8
    Two in one day....
  3. Schnee197
    33
    62
    I'm on fire bud.
  4. dcjones
    dcjones forum member
    100
    Trail braking entry is a waste of time. No one does it. E-brake or clutch kick depending on the course layout.
  5. Schnee197
    33
    62
    Ok. My ebrake dosnt feel like its got enough bit to lock the rear tires, any suggested upgrades?
  6. fivehunsky
    fivehunsky forum member
    260
    The factory ebrake works just fine. Just pull harder. And remember to push in the clutch when you do.
  7. Silverrider
    Silverrider forum member
    598
    So when you pull the ebrake hard and engage the clutch you steer into direction of the corner once you start drifting you release and punch the gas right? Sorry trying to understand drifting a little more, I would love to learn how to better!
  8. fivehunsky
    260
    Where are you located? There are alot of different variables to drifting. It would be much easier to just find a local event to go to and practice. DO NOT street drift to learn unless you can afford to fix you car. YOU WILL eventually wreck or get caught.
    If you want a video to watch to help learn find "the drift bible." It goes over all the basics and helps you learn how to do it right instead of teaching yourself how not to do it right then having to re-learn it later :)
  9. Silverrider
    598
    Haha, I don't drift in the street, just kind of want to get into it, have watched a million videos and I am to the point where I think I need to try. I am in manhattan, ks.... nothing that I know of goes on anywhere around here...
  10. krang00
    krang00 forum member
    379
    this
    I usually give a quick toss the opposite direction of the turn, clutch in, quick e-brake and on the gas for most entries. But like above, it really depends on the course layout.
  11. Xile
    Xile forum member
    200
    Can you drift in automatics?
  12. Silverrider
    598
    You can drift anything dude!
  13. mancha
    mancha forum member
    118
    The ole Scandinavian flick? Classic rally technique.
  14. Beef Supreme
    Beef Supreme forum member
    54
    That's what she said.
  15. Dreadknought
    Dreadknought HOON MONSTER
    1,053
    So what are those particular examples where which is better?
  16. dcjones
    100
    E-brake works well if you need to decelerate or slow down after you initiate a drift. Road Atlanta is a good example. It also works well if you need to get the car to rotate fast but don't want to pick up speed while doing so.
    Clutch kick works well if you need to accelerate through the initiation point to have the proper line going to the first clip point or apex. This will keep your speed up as well.
    Both are used through a course to adjust line or keep the rear tires spinning.
  17. Godzirra
    Godzirra Asian Idiot
    29
    923
    All right look man there lots of ways you can do this all right. Handbraking is the easiest so the first thing I want you to do, I want you to rip that E-Brake all right. After you rip that E-Brake then I want you to power over.
  18. Scrape
    Scrape forum member
    132
    Interesting techniques...
  19. sick3v
    sick3v forum member
    90
    just try not to wreck Mona :roflmao:
  20. Dreadknought
    1,053
    Perfect! This will be a big help with the learning curve. Thank you.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
