Mustang GT/GT500 Part Out (all kinds of hoses/engine accessories/etc)
GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
Listing updated 03/09/2014
Items Still Available:
*Both Heater Hoses
*Stock Clutch Line
*Stock Differential Cover
*MISC, just ask
4.6L 3V Heater Hoses $12/ea shipped
4.6L 3V Brake Boost Hose $12 Shipped
Stock Clutch Line (from model year 2009) - 20 Shipped
Stock Differential Cover w/ Bolts - $13 Shipped
All items shipped from VA, 22312. Local pickup is accepted.
If you are looking for standard equipment on the Mustang GT, PM me as I may have it but haven't listed it yet.
ITEMS SOLD
-Stock Fuel Line - SOLD TO porkipine
-Stock GT A-Arms - SOLD TO porkipine
-Stock 2009 Coil Plugs - SOLD
-Stock GT500 Throttle Body - SOLD
-Both 2009 Mustang GT A/C Lines - SOLD to saintsfan
-2009 Mustang GT A/C Compressor - SOLD to saintsfan
-Slave Cylinder - SOLD to 555
-Power Steering Pump - SOLD to 555
-Stock Bullitt Sway Bars (Front + Rear) - SOLD to Autonut
-Stock Bullitt Springs (Front + Rear) - SOLD to Autonut
-Power Steering Tank OEM - SOLD to Saleen304
-Mustang GT 3V OEM Power Steering Line (shorter line from rack to motor) - SOLD to Saleen304
-Mustang GT 3V OEM Power Steering Line (longer line that runs around AC condenser) - SOLD to Saleen304
-Mustang GT OEM Denso Alternator - SOLD to deux2k5
-Mustang Bullitt Shocks/Struts - SOLD to Jambarino
-Mustang GT 3V Engine Wiring Harness - SOLD to BruceH
-2009 Mustang GT Battery Harness (I believe it is the same for 05-09) - SOLD to member on SVTP
GallopingFord
Northern Virginia
Are bullit swaybars an upgrade for regular GT's?
As stated in the Bullitt overview - Suspension includes "Sport tuned Suspension (shocks/springs/stablizer bar)
I am not sure of the technical specs on them, but I believe they are an upgrade over the standard bars.
*Mustang GT A-Arms added to list
GallopingFord
Northern Virginia
Stock GT A-Arms + Fuel Line SOLD to *porkipine*
*Power Steering Pump added to list
*AC Compressor added to list
*Battery Harness added to list
*Alternator added to list
I also have coolant hoses available (not listed yet)
GallopingFord
Northern Virginia
Sorry about that. Slipped my mind on the date with my username. I'll have them when I get back to the shop on Monday/Tuesday
saintsfan
Are the two listings ($40 and $50) for all the a/c lines? Did you have any a/c leaks?
GallopingFord
Northern Virginia
Yes those are the two main AC lines in the engine bay. They are perfect, only 23xxx miles on them and removed due to my engine swap.
saintsfan
Okay, I've got an a/c leak and may as well pick these lines up. I'll PM you.
GallopingFord
Northern Virginia
The manual transmission harness is built into the engine harness. I don't have a automatic if that is what you are asking.
GallopingFord
Northern Virginia
Items Added!
*4.6L 3V Heater Hoses
*4.6L 3V Brake Boost Hose
*Power Steering Fluid Tank
*Power Steering Line (this is the line that connects from the steering rack, routes around the front of the K-member and then to the power steering motor)
