My install thread :D
onehotpny
Aragon,Ga
yea if you look at the front of the center section the flat carpet actually dips down and doesnt seal up, i am probably going to figure out a way to connect a few small pc fans to get air flow moving through there.
yes it does get really effing hot
Might want to do two air pumps instead of one.. with two pumps it would take less time to fill air tank,meaning less compressor run time"just an idea" question, does your compressor run all the time or just till it fills air tank? you would think with the pan tank it would hold a good bit of reserve air in the tank. I don't know much about air ride systems , but I airbrushed for over 25yrs , before I drove a truck. so I've had a good many air compressors in my days, one of my favorites is the quite series compressors , which uses basically refrigerator motors. too bad you couldn't take a 12 volt converter and use that type of compressor..
Anyway I'm sure you'll figure it out..:beer:
Wes06
yea the dual compressor is an idea im throwing around, will decide later.
only runs until the tank fills to X, usually 170psi, and kicks on at 110
2BlownStangs
Tampa, FL
hey Wes, I was just looking at this thread, the pics that you posted, is that as low as the car will go?
Wes06
atm yea, i still havnt gotten around to trimming the rear bumpstops. one day ill get to it......
i really need to cause im basically riding them at ride height as it is
