cdutchess78
so i ordered new wheels from tirerack.com. i used the drop down meneu to locate exact specs for my vehicle and when i got them in,i went to tire place to get them mounted.the rims i ordered are not fitting due to rubbing against my brakes.they are factory brakes with 18 x 9 wheels.
my question is:
what is it called as far as the minimum distance i need to look for? Is it called offset,backspacing,something else? if you know what its called, what would be the minimum distance i need to look for? Im by no means a wheel expert so could really use help to make sure this wont happen again.
wheel name:Enkei Performance LS-5
Offset: +40mm
Backspacing: 6.61"
Bolt Pattern: 5-114
my question is:
Offset: +40mm
Backspacing: 6.61"
Bolt Pattern: 5-114
