Need Help Leaky Injector
tached_out
Bigger the better
I think that my injectors are leaking and need to get them tested. Does any one know a good place to get them tested and to match them. I was told that allot of times your injectors will not be running the same.
Like one will be 20% more rich or lean then the other. I need some more info on this my car flooded out for the second time all ready.
tached_out
Bigger the better
Thanks I found a place in fresno that will do a flow match as well for 28 a piece. Man this is costly just to see if this is why my engine is flooding out.
We think I have a leaky injector and while it sits it just leaks into the car. If i drive it all day its fine. Its only when it sits. So While it sits we think its just building up fuel.
If I go WOT and fire it up it shoots black smoke and fires up and runs great and will start after that as well.
tached_out
Bigger the better
After testing we noticed that one injector failed and one was leaking. I have two more new ones on there way should have them in on friday
Bigmike0405
Whine and dine
PA
man i cant concentrate on the post because of the sig pic man that is sweet
+1 dude those things just bounce! OMG I would let her drive my mustang if I can drive her..... right into the WALL!!! ahahahahaha:evillaugh:
