Need help, rear shocks?
bjtheman1
Texas
Ok, I'll get to it. Installed new rear shocks, top hex on one broke off...other one is pretty jacked up. I tried my impact but it didn't help!
I still need to get them tightened down more, what can I do for this?
skwerl
tree hugger
central Florida
Reach in the wheel well with one hand and hold the shock by the dust boot. Reach in the trunk with the other hand holding the impact and buzz the nut down. Don't overtighten it.
Kalatrax
Albuquerque, NM
I can't remember how much thread is there but if you can fit two nuts on top of the main one you could use the middle one to hold the rod from spinning.
Kylar
CT, USA
Most of the time there is either a flat spot on the shaft, or an allen key where the nut goes on to keep the shaft from spinning. Or if you want to get super ghetto vice grips and a shop towel on the shaft...
