NRG-GT
The car starts and idles fine with no issues. When shifted in to reverse the RPMs drop to 500 and bounce up to 1000. The wrench light and check engine light come on. Also shows an ODO error in the display. When I try to accelerate the car try's to move slightly but goes no where. Same occurs when the car is shifted to drive.
If I put the car directly into 1st 2nd or 3rd I am able to drive it but tops out at about 30mph. Shift back to drive and the car will no longer accelerate and only rev up to about 2500 RPMs. The engine code is a P0720 which is the output shaft speed sensor.
Turn the car off and back on it goes back to idling fine until shifted again.
http://youtu.be/IVeOjpeo_nw
