Need help with factory HIDs
ExSRT8Guy
Been There, Done That
Scotts Valley, CA
Low-mile '08 GT Premium, with factory HIDs.
Right one didn't come on last night, either high-beam or low. Figured the bulb went out; I'll get a new one. Holy shit! When I saw the price, I thought i'd looked up the assembly, and not just the bulb.
Before I kick down that much, two questions:
  • Is there an easy way to confirm it's the bulb, and not the ballast?
  • What's involved in replacing the bulb? There's a lot of info on aftermarket HIDs on the board, but couldn't find anything for factory.
Can't believe that bulb price!
ExSRT8Guy
Scotts Valley, CA
I would like to make sure it's the bulb before I kick down for a new one from Ford, or eBay. Is there a trick to replacing these? Looks like a simple connector, but I'm guessing it's not that simple :helpme:
eighty6gt
You can find them on ebay for pretty low. I snagged a set of 08/09 GT500 HID's last week for $400 shipped.
Including the housings, new?
I would like to replace my housings as they are getting pitted.
GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
That was everything except the wiring harness ( which I already had)
Just keep a look out. There are some experts who can revive pretty badly pitted housings though.
skwerl
tree hugger
central Florida
Check the relays first. They have their own separate relay box on the front of the passenger shock tower. There will be two relays in it. Swap the relays and see if the dead light goes to the other side.
ExSRT8Guy
Scotts Valley, CA
I ran out to the garage, swapped 'em, and... no difference. I was really hopeful, though. You can hear each one click, the way it's supposed to.
Great avatar, by the way!
Kylar
CT, USA
If it is the bulb, no need to pay ridiculous $$$ unless you want to throw away money. Just hit up ebay. D3R is the bulb type i believe, they can be had for $35-$50 a pair
ExSRT8Guy
Scotts Valley, CA
According to Ford, it's a D1S. The aftermarket shows D3R, which is similar, but not exactly the same. I'm going to tear into it this weekend.
