OK, so we finally narrowed down my rear clunk to be most likely the slip joint in mypowerhouse driveshaft since it has some paly back and forth.
Now, after having the CHE K member brace/torque limiters installed, i've noticed that I have a clunk from the drivers side front end whenever I turn the wheel to the left and then back again (clunks going both ways).
At the shop today we put the car up on the lift and checked all over the place. Cannot find anythign that looks wrong/needs to be fixed. Nothing is rubbing or even close to rubbing and all bolts are tight. Front tires were also checked and everything is right.
Any ideas on anythign we might have overlooked to check?
