New engine build
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Pic of the day
Enviado desde mi MotoX
A broken shop door knob???? Have you Dyno'd it yet? Lol!!
lito
Caracas, Venezuela
Looks like something has been modified, maybe in a lathe?
Yeap, the marks are because of the balancer that was already in and it is tight tight. There is an issue there but nothing can be done now but I think it may work even with it, we'll see.
dysan
Dis-Member
Williamstown, N.J.
To get the tight balancer back on it you can most likely heat up the center of it(balancer) with a good heat gun before you try to put it on. I had to do that with my innovators west balancer. Also put a light coating of anti-seize on the crank snout.
crownaviation
http://www.tudyno.com/
Broke dafuk down
Oven @200° for about an hour
I have seen people hammer then on. Omg they wonder why they have problems in life in general
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Looks like the woodriff key is messed-up on the end.
That that "wheel spacer" not fit on there?
Good luck, and waiting for the results.
lito
Caracas, Venezuela
Is a Roush UDP (looks really nice BTW, way better than Steedas, if you one makes the typical and some times idiotic "looks" valuation) and plan is to use some sealant at the key as with the others. I think the snuggy fit is more because of the reworked nose.
And that is the first thing they tell you not to do, the thing is that I don't know why, I see those people most of the time get away with everything and I that am very picky with stuff, gets very unlucky.
It has all been custom modded but is good, only issue is that the key can't be moved farther back and is not long enough to safely grab the rear TFS gear so I wont be degreeing it.
Results? Well, no results for a few weeks, I may be the only idiot in the planet to break a ring using an ARP ring compressor. For some reason this one doesn't works as my others did and broke an end of an oil control ring. I hate myself today.
BruceH
BBB Big Bore Boss 322
Any advice on where to get these rings fast?
Ford dealer? They usually sell them in sets for one piston. It's just the oil control ring, right? If it's the center part that holds oil you should be able to cut a larger one down.
lito
Caracas, Venezuela
Is one of the upper/lower control rings, I don't now if these are the same as the stock ones, these are Mahles.
lito
Caracas, Venezuela
Mahle got back to me and got to order a single piston set of rings, with luck I would have them next week, with all the freight it will cost me about 60$, yay! :thud:
In the meantime, pic of the day:
Sent from my Nexus 7 using Tapatalk
crownaviation
Broke dafuk down
So 4.6 block but what crank? 8 bolt but can't identify it. Also what bearings are those? Not oem or clevite. Sealed power?
Also can't tell but did you install the other half piece of the thrust bearing?
lito
Caracas, Venezuela
A crank that howls at the moon at night. Custom made bearings done here from a sold brass piece.
Yes, 3 pieces are installed.
Pic of the day
