New Motor Smoking??
bry9
Crown Point,IN
What are your opinions? It puffs white smoke at startup... If idling for 1 minute or longer it starts to smoke.... If driving around it seems ok.... But when i come up to a stop sign using the motor to slow down.. (stick car). It puffs alot of smoke upon accelerating??.... If I run the car for a while,then turn it off,and immediatly start it up again it puffs alot of smoke... It all smells like oil???
Valve seals or oil rings???
I already changed out the Turbo,and its still the same.........
94tbird
4R70W FTMFW
NY/NJ
head gasket possibly? leaking coolant? thats what comes to mind for white smoke. i believe Don had the same thing, turned out to be the heads i think
bry9
Crown Point,IN
I did put heads from BBR on it upon rebuild. I am thinking valve seals.. Its definitly oil,you can smell it...
94tbird
4R70W FTMFW
NY/NJ
definately get it checked out and let us know!. hopefully it isnt too bad
bry9
Crown Point,IN
Ya, Im going to pull the heads this weekend... It almost seems like there are no valve seals in the heads..... I pulled the plugs,and I can see oil sitting on top of the pistons in the valve reliefs..
Hawgman
THE fucking bad guy
Texas
Paco Pony has the same issue with his stroker. Been fighting it for a couple of months now. Has smoked since the day it went in.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Zackly... I had a crack in the head. Adam diagnosed it in a matter of minutes by using some sort of "sniffer" tester that could detect gasoline in the coolant overflow tank.
BTW, is your coolant level dropping or holding steady? My would slowly drop, which also was a good indicator.
bry9
Crown Point,IN
No coolant loss, it has the distinct oil smell out the exhaust.. I am pulling the motor this weekend.... Thinking the rings did not seat properly..
I have changed out the Turbo ,and no change,so its either the heads or rings.....
matt texass
i have heard somewhere of others with BBR heads having this problem dont remeber where maby it was on that .......other site
94tbird
4R70W FTMFW
NY/NJ
i seem to remember that too but cant place the person at the moment
matt texass
all i know is that ive heard horror stories about bbr and will stay clear of them
s8v4o
Is it white in color or a very light blue? Why not perform a compression test?
bry9
Crown Point,IN
Motors out. Heads are ok.. Its the rings.... I know of 3 other cars having the same problem right now.... wonder if a bad batch of rings got out??
MikeVistaBlue06
Inventor: Asshole Points
Richardson TX
What kind of oil are you using? Break it in on dino oil--do not use synthetic for break-in.
Those rings may need to scuff in better to seal, especially if they are moly coated rings.
Hope this helps.
Mike
bry9
Crown Point,IN
Update..
Pulled the motor apart. The ring depth was wrong... received new set of rings,and they have a .044 difference.. I bought the pistons,and rings from somebody as a set.? I guess I should of checked them closer.....
The car made 650RWHP with the wrong rings..
Will have it running again this weekend.....
