New user from SOCAL
frigidreflection
Okay so heres my car bought i brand new in 06 and i just couldn't leave it alone, the paxton was installed instead of the KB just cause i wanted more of a track oriented car and i wanted a certain power at a certain rpm range.
Performance Modifications
Paxton novi 1200 supercharger -6 psi pulley
SCT XCalibrator 2 Tunned by "The dyno shop" in San Diego on a Very mild tune 428hp
Ford Racing High Performance Dual Fuel Pump Kit
Ford Racing Fuel Injectors
MSD Coil on Plug High Output Coils
Steeda Billet Throttle body spacer
Steeda Charge Motion Control Plates
SLP Coated Long Tube Headers
Custom made 2.5 in X pipe with test pipes
Magnaflow 2.5 in magna pack mufflers to 4" chrome tips
Custom Billet Oil filter relocation kit (holds at least 1 extra qt of oil)
Drivetrain
Ford Racing 3.90 Gears
Tremec TKO-500 Transmission 5spd Close ratio 600 ft/lbs max tq capability
Custom Made Billet shifter for TKO with Hurst Pistol Grip Shifter
Steeda Aluminum light weight one piece Driveshaft
Fidanza Aluminum lightened Flywheel
RAM Street Dual Disc Clutch
Brakes system upgrades
Agent 47 Brake Cooling kit
Agent 47 Brake Duct kit with front fascia
Steeda Stainless Braided Brake Lines
DBA High Performance Brake Rotors dimpled and slotted
Hawk High Performance Racing Brake Pads
Suspension Upgrades
Steeda 3-Point frame rail and torque box
Steeda Front strut tower brace
Steeda Rear shock tower brace
Steeda Rear track bar
Steeda Rear Swaybar Mount Brace
Eibach Rear sway bar
Steeda Front Swaybar Mount Brace
Eibach Front sway bar
Steeda Adj sway bar billet end links
Steeda Adjustable Panhard Bar
Steeda Adjustable rear UCA
Lakewood Fully adj LCA
Tokico D Spec Shocks & Struts 16-way adjustable
H&R Performance Springs
Wheels and Tires
Weds Racing 18x9s in front with 285 nitto 555r's
Weds Racing 18x10s out back with 305 nitto 555r's
Apperance Products
Steeda Race Wing
Steeda ABS Front Splitter
Agent 47 Brake duct front fascia
Agent 47 Black Billet Grille proven to increase air flow
Steeda Ultralite Full Cowl Induction Hood
Steeda Billet Hood Strut Kit
Sparco Racing Hood Pin kit
Steeda Sidewinder Stripes
Steeda sequential tail lights
Mustang Quarter Window Louvers
3D Carbon - U-Shaped Rear Window Trim
Xenon Mirror Cover Set
CDC windshield Squirter Nozzle Relocation
DG Custom Side Scoops
Auto Meter Custom gauge pod setup
Autometer Gauges Boost, Air/fuel, oil pressure
HOLYWD
S197 Junkie
I would have to say your car actually can pull off that spoiler
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Herknav
Devil's Advocate
Arkansas
Welcome!! :beerchug2:
I was getting ready to bust your balls over that comment... until I realized you meant one of those tracks that has curves and shit. :idea:
Tracks eventually come back to the begining... I think you're talking about a "strip"... :idea:
