Nitrous and fuel question
firestang70
SW Ohio Ninja
Searched with little success. Purchased a used plate kit and planning on a 150 shot wet. For safety will be running 1 step colder plugs and Torco, progressive controller. My question is will the stock 5.0 inj and pump stay within an acceptable range? Goal is to run a bottom 10. Thanks in advance.
onebadgsx
Houston, TX
Stock pump is good to 600hp. So your fine on the 150 shot. Get the ngk plugs. Dont run the frpp platinum plugs.
DVEST8R
yes i have a friend with a 2011 doing this on a stock fuel system
firestang70
SW Ohio Ninja
Thanks for the responses guys. Jason I have NGK plugs coming, thanks for the recommendation.
Neal@
Waco, TX
Being that it is a wet system, you will not need to worry about injectors since the fuel is being supplied by the nitrous solenoids. The fuel pump on the 5.0 is good for some serious power. Depending on the power you are making will determine if you need a boost a pump or not.
