Noise Issues that I need help with
Boaisy
Dark Knight
Memphis, TN
Problem with Redline is that it is a synthetic oil. Truetrac's are designed to use dino oil, and there is a good number of people having various problems when running synthetic (premature wear, noises, slippage, etc.). It is kind of a crap shoot if nothing bad happens at all actually as there are a couple who have run Royal Purple with no issues (though those people just DD the car). I run mainly Autocross's/HPDE's and DD the car.
skwerl
tree hugger
central Florida
I put Lucas in mine when I installed the Truetrac a couple years ago. Many many trips to the drag strip and it's never given me a peep or hint of an issue. The Lucas was so thick it was like trying to ladle cold bacon grease into the differential.
Boaisy
Dark Knight
Memphis, TN
I thought about Lucas too, but the main question is the 85w-140 dino that both Lucas and Torco offer. Would it be too much weight for our cars? I do live in west TN where the summers hit the 100's. Would it be better than the 80w-90? I don't hear of a lot of people using that weight, most use 80w-90 for dino, 75w-140 for synthetic.
skwerl
tree hugger
central Florida
The thicker lube is better in high heat situations IMO. It gets kinda hot here as well. You do need to let it warm up a little before pushing it hard. I drive real easy until the engine is up to temp, by that time the rear is also warmed up a bit.
