I have a Vortech S-trim, no intercooler on my 91. with GT40 crate 302 (340 hp rated) I get 8 psi boost. Runs for 40 minute sessions at HPDEs without issues.
I don't know for sure, but it has never exceeded the IAT limit I set in the tune. I have the IAT vs Timing function cutting timing 6* if IAT gets to 175*~ish. I forget the exact value I set, it's been a while since I put that tune together. 12.1 AFR, 18* WOT running pump 93.What are your intake temps like?
Does it slowly ramp up to 6 degrees of timing retard or does it get all 6 degrees at 175F? Just curious.I don't know for sure, but it has never exceeded the IAT limit I set in the tune. I have the IAT vs Timing function cutting timing 6* if IAT gets to 175*~ish. I forget the exact value I set, it's been a while since I put that tune together. 12.1 AFR, 18* WOT running pump 93.
I would doubt that it ever gets in that temp range at 8psi with a centri. But just a fyi, I used to just pull 5* of timing when using a 125 shot on my old 03 Lightning, and just to experiment, I made a pass without nitrous and the same -5* timing for nitrous anticipation, and it ran the same time / speed at the same track that it did before I added the nitrous and subtracted the timing. You might see something on a dyno, but my track times didn't change, and applications can surely vary. Long story told short, You might not notice if it ever pulled that timing you're mentioning.Its 0* or -6* no ramp up. So it should be a noticable loss of power if it hit the temp limit. Also, I'm running the UPR intake. (MAF inside fender) so the incoming air is as cool as possible.
I agree, I've seen high 150's spinning the hell of a small M112 Eaton on both a Cobra and Lightning that I'd nearly promise produces more heat than a centrifugal at less than 10psi175 degrees is pretty high in my opinion. I'd think it would start detonating before that. But I'm no expert.
I do know that even with my F1A spinning pretty decent IAT's were never more than a few degrees above ambient. That was with the Procharger 3 core intercooler.
Misspelling brought to you by Tapatalk
