@Terry
What do you think of staggered fit, like the Boss, for the Mustang on road courses? I was thinking of doing 10" in the front and 11" in the rear.
Thanks
Personally I'm not a fan of staggered fitments on almost any race or street car (with exceptions for rear engined and/or extremely high powered cars). A lot of OEM cars come with a staggered wheel/tire width front to rear, and in 100% of those cases it is narrower fronts to ensure UNDERSTEER. There are liability reasons why car makers have almost universally tuned their cars to PLOW / PUSH / UNDERSTEER from the showroom floor.
When cars start to do ^^this ^^ most drivers tend to crash. A lot. Why? Because the natural tendency is to lift the throttle or jam on the brakes when a car begins to yaw into Oversteer, which only makes matters worse. Doing that causes more weight to tranfer to the front axle, increasing front grip and lessening rear grip. The cure for oversteer is actually the opposite: to apply more throttle (temporarily), to counter-steer, to increase the turning radius, or some combination of the 3. (the car above doesn't normally oversteer, but I was doing the driftoro thing on purpose)
Conversely when a car is plowing like ^^ this ^^ (which Mustangs tend to do when pushed hard) those same natural driver tendencies (lift throttle or apply brake) actually helps cure the condition temporarily, so auto makers tune their cars for understeer. At all costs. When it comes to sportier cars, they help this by putting narrower front tires on the car relative to the rear. Corvettes started doing this in the late 1990s, 911s have been doing it for decades, Vipers have always had staggered fitments, the Boss Mustang, and on and on.
This tendency for massive understeer is my least favorite thing on any OEM set-up. Unless the car has massive horsepower relative to braking and cornering grip, this staggered wheel trick isn't needed or in any way desirable. For almost all Mustangs I would start with an 18x10" front and rear first, unless class rules didn't allow that (and if so, I'd switch classes, heh!). That's a great dual purpose street/autox or street/track wheel size, as it allows for up to a 295mm tire and you can rotate front to rear. Beyond a certain level you will want more tire, so I'd go with the 18x11 front and rear. Then you need to start thinking about cutting fenders for a 18x12" front and rear set-up, where we are now with our TT3 car. And even then, it isn't enough tire. At the 3770 pound race weight we have to run for the power we make in this class, it is easy to overheat even the 315mm tires we use.
In the video above (which was from the first session at TWS last weekend, on a semi-damp track) you can see classic cases of oversteer and a good recovery at 2:18, and snap oversteer and a loss of control at 2:41, even with an experienced driver trying to catch it. Oversteer isn't fun, and I'm not saying that going to a square set-up will make that happen. In the wet it happens on almost everything. But in the dry you don't want a skinny front tire relative to the rear, almost ever. And not on any S197.
