BruceH
BBB Big Bore Boss 322
I'm wondering what does it cost to offset grind a crank? Specifically taking a stock 4.6 crank and offset grinding the rod pins to sbc size of 2.000". Since they start at 2.087" we should be able to get at least a 3.717" stroke but maybe more. I'm having a hard time picturing the base circle in my head and how it would shift with the offset grind.
The whole reason I'm asking this is because some people just have to have a stroker and prices for stroker cranks have gone through the roof. The only exception to that is the Eagle crank for Honda journals that goes for $300 or so. The only problem with it is that you need modular 5.850" rods for Honda journals and as far as I know Eagle is the only place to get those. For some reason they charge about $650 for a set so it puts the inexpensive Eagle cast steel stroker crank out of the picture imo.
Just wondering.
Just wondering.
