Offsets for 11" wheels
FR500GT
Orange County, CA
So I found another possible option, The Forgestar F14's in Matte Black. Looking to run a 19x10 front with a 19x11 rear setup. Tires will be Michelin PS2's with a 275 front, 305 rear (I have access to porsche takeoffs for cheap).
Since I have the option on offsets, I want to make sure I order the right one. Looking to have it sit flush front and rear but still not poking since I will also be road racing(dont need it hitting the fender on the apex lol). I'm guessing a +40 front with a +45 rear would be good. Any and all input on ideas for the correct offset is much appreciated!!!
FR500GT
Orange County, CA
Arent you using a +45 (and now going with a 5mm spacer)? I do realize that you are running a narrower tire. Does the actual rim tuck, poke, or is it flush with the fender?
Jax FL
you could pull the rears off with the right tire and a fender roll/pull but a 305 would be hard with that offset. my rims equal out to be almost your exact offset in the rear but are 10" with a 32mm and i had to roll the fenders and pull them just a hair but if i had a wider tire then it might start to scrub but im on coilovers. You could do it with a 285 and maybe a 295 a 285 might looked a little stretched. How low is your car cause if your not slammed on coilovers or anything i think you could pull it off, but a 50mm rear would be perfect if thats a possibilty.
Kobie
Call Steeda. They have a 20X11 wheel that they run with a 305. They should be able to tell you about clearance issues.
Infamous
BMW
PeetieWonder's Wildest San Diego Dreams
the actual rim pokes over 5mm, dont have an actual measurement but it is out. i may space it out for more poke
i'll go re measure this weekend (or thursday if i get out early) but IIRC 50 should be approx wheel flush w/ the fender; a 305 will blob over just a little; 55 should have the entire setup including wheel under the fender. check with the manufacturer as well
remember, even if your tire/wheel is in the fender doesnt mean a big impact wont take out your left fender because of our panhard setup depending on your drop setup
FR500GT
Orange County, CA
I guess im just worried about it rubbing on the inside. So maybe +40 front, +50 rear. Im gonna contact Steeda like Kobie suggested.
Perfect, will do!
Thinkkker
Spring, TX
On 10.5 with a 35 offset there is 1.5" clearance inside with about a .75-1" sticking out.
Take it for what its worth.
Jax FL
:headscratch:
I thought the rear fenders are already rolled? How are you rolling them further?
yes they are rolled but its just a common way of saying it, you use a fender roller to pull the fenders out slowely it takes time to do a good job but it can be very effective if the person know what there doing.
