Oil dip stick readings low
o2sys
NY/NJ
Sometimes I check my engine oil dip stick and either reads low or smears all over the stick.
So I freak out and do an oil change and to my surprise all 6 +\- quarts come out???
BruceH
BBB Big Bore Boss 322
No I'm serious guys
This is one reason for the holes between the hash marks. Sometimes residual oil will smear and obscure the reading. However, the holes can only be filled by being submerged. So provided that the bottom hole is filled you should be ok. I'll also add that once you get a fix on the bottom hole it's easier to see just where the oil ended up on the hash marks. Oil on the hash marks is only going to be consistent where the hash marks were submerged.
Does this help or clear anything up?
Scott_0
OxFORD, Pa
do you wipe the dipstick clean then reinsert for your reading? or are you driving the car, letting it sit for however long, then pulling the dipstick out and reading it that way? I mean, how hard is it to accurately read the oil level? lol
Townson
Alabama
Let it sit overnight, pull dipstick, clean it, reinsert, take it out and check it. Don't freak out. Get a prescription for Xanax. It'll be fine.
Kylar
CT, USA
This, its best to check when cold, and on a flat surface. After driving there can be some oil in the tube that can throw off readings.
07 Boss
Sin City
Back in the day (1970's) I worked at this service station when full service was the norm. My boss told me when I checked someone's oil to not put the dipstick all the way back in when checking it so that I could sell them a quart of oil that they didn't need. Effin Crook.
o2sys
NY/NJ
Lol
eighty6gt
The dipstick for some reason never reads correctly on these engines. Always smeared up and useless for me. My tactic is NOT to pull or clean the stick - just pull it out after car has sat over night in the garage. There's your reading, clear as day. Don't worry about capillary action or some other BS drawing oil up the stick.
Scott_0
OxFORD, Pa
lol wow! so wrong
lol not the first time I've heard this complaint, I just don't get it man, it's not brain surgery smh
Sent from my S6 using tapatalk
skwerl
tree hugger
central Florida
Man I must be a brain surgeon because I don't have any issues with this.
You and me both. Every time I change my oil I run the car for a few minutes and then shut it off and check the oil again. That right there tells me where my 'full' mark is on the dipstick regardless of where the scribe marks are. And somehow I manage to remember that little tidbit of information whenever I check my oil level.
If it reads funky then wipe it off and try again. Heck, maybe even wait a minute or two for the oil to finish draining down into the pan. I'm trying to be helpful here and not sarcastic because I realize not everyone here has been changing their own oil for 35 years and not everyone grew up in their father's service station. Therefore stuff I tend to take for granted might not be so obvious to others.
Scott_0
OxFORD, Pa
lol I was saying, checking the oil is not brain surgery, and I don't get the complaints, hell I've heard gripes about the strut tower brace being in the way and it's a bad design complaint as well
