mike maloney
Resident Fuktard
- Joined
- Dec 29, 2019
- Posts
- 73
- Reaction score
- 15
Having a strange issue on a mechanical oil psi gauge I put on my 2014 coyote.I put a 75" long braided stainless reinforced Teflon line 3/16" reducing to 1/8" copper line 3" to the gauge.
On engine running I am hearing a slight chatter at the gauge.I pulled gauge off and put another one (both are bosch 0-100psi) Made sure the 1/8" copper line is completely open &
the needle is steady)Still getting the chatter. Felt line & started feeling pulsing about 50" from oil line connection at oil pump.Pulsing increases as rpm increases.Is it possible the reduction of oil line at the gauge is causing this? Iwill be plugging line before reducer fitting just to check if
pulsing quits.if it does not quit,any suggestions? (oil psi shows 100 cold &50-60 warm idle)
