Open Ended Lug Nuts
Jinx
Photography Blogger
Mebane, NC
The diameter of my wheel's lug nut holes are very tight. I have light marring on the inside of the holes and light scratch on the rim of one of the holes. Anyone recommend any brand or place to get some like these for mustangs?
Jinx
Photography Blogger
Mebane, NC
I seen the McGard lugs, No lugs using a inner key like I pictured? Its very tight.
908ssp
Michigan
With the spline drive the socket is usually smaller so I made a nylon sleeve to cover the outside. You could put a couple layers of shrink tubing to cover the socket.
LS1EATINPONY
The Banker
Ill have to find out who makes them but a friend of mine bought some 2 piece lug nuts for his s2000 since he put a fairly pricey set of wheels on it and the selling point is the face that the out part of the lug spins freely so once it gets pressure on the wheel it will not move, allowing the inner part to spin so the lug nut can tighten down and not mar up the finish on your wheels. He swapped his wheels many times and never once had a single issue with scuffing his wheels.
