Chilliwack 42
A few weekends ago my car threw a P0300 code. I have Comp Mutha Thumpr Cams so it was hard to tell when it was missing. I've had the cams for a few years and they we're installed by my dealer so I don't suspect an install issue. The only thing I have done to my car this year was replacing the stock clutch and flywheel with an Exedy setup. Oddly enough my car ran it's best time 12.24 @110 while it was throwing a misfire code.
I'm going to check the plugs and COP's this winter and likely replace the plugs since I'm going to the trouble of pulling them. It probably wouldn't hurt to change the fuel filter and check the injectors as well.
I've been doing some reading up on here and I'm just wondering if I may require a Misfire Monitor Neutral Profile Relearn. From what I've read it seems changing the clutch and flywheel on a 5.0L can cause this code. I'm curious if the same goes for a 4.6L.
